idle engine speed
To fix this I set the idle speed screws so I had 20 thousands of the transfer slot visible in the primary and secondary, then dialed back the 500 RPM timing set point to adjust the idle speed down to 800 RPM. The car runs perfectly now. I can't remember the exact value I used at 500 RPM. But from 1000 RPM and up I have more normal values. I do run vac advance. I think I had to keep the static + vac advance under 20° to get the idle speed where I wanted it with the blades still open the right amount.
I think the reason my car idled so fast is I am running a stock LS2 cam that is pulling something like 23 inches of vacuum.
By the way, it is pretty easy to drill out air bleeds and tap them for set screws you drill yourself. That is what I had to do to get my transition circuits tuned right.
