Carbed L92 engine-which front and rear covers
Can I run the stock front and rear covers and buy the corresponding MSD box for the 58x reluctor wheel? Thought I read somewhere Id need to change these out
It's the front cover you have to change because of the vvt...you will also have to switch to a 3 bolt cam....Martin over at tick performance sells the vvt delete kit you will need its just over a 100 bucks...check it out...
