Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Help !!!
Old Sep 1, 2013 | 09:41 AM
Doug G's Avatar
Default Help !!!
New laptop and port for the MSD to plug in
WTH do I do now...what adapters work ????
Old Sep 1, 2013 | 10:27 AM
89gmcs15's Avatar
I bought a cheap one from eBay and the driver never worked. Then I bought the speedy one msd recommends and it works good.
Old Sep 1, 2013 | 11:48 AM
Doug G's Avatar
Just got on MSD site...Thanks
Tech Tip - Recommended USB Adapter: IOGear GUC232A
IOGear-CouponCodeThe adapter cable is available from “IOGEAR” www.iogear.com part number is GUC232A IOGEAR calls it a “USB to Serial/PDA Converter Cable”
IOGEAR has offered our customers a 20% off discount. Please use this coupon code when shopping at IOGEAR: MSDIGNSA
Note: MSD has discovered the majority of USB to Serial communications problems are derived from device driver software. The device driver software is included with the USB to Serial Port Adapter by the adapter manufacturer. The device driver software must pass Microsoft Windows driver certification in order to operate the adapter correctly. IOGEAR has updated device driver software available for download on their website that is compatible with Windows 7 32-bit and 64-bit versions. MSD Ignition recommends the use of the IOGEAR USB adapter over other manufacturers.
Old Sep 2, 2013 | 08:49 PM
3pedals's Avatar
Frustrating isn't it, MSD needs to get their $hit together and step the tech up into the 21century, and add a usb port instead of the antique serial port
Old Sep 3, 2013 | 03:29 PM
Doug G's Avatar
Absofreakinglutely
Old Sep 23, 2013 | 07:53 PM
Doug G's Avatar
Well...just to let you all know....went to radioshack and bought a Gigaware USB to Serial adapter and then since it's not Windows 8 compatible, I had to go to Microsoft site and down loaded an update.... Back on line with the MSD box.
$24 and no shipping Just for future info
Old Sep 23, 2013 | 08:15 PM
Loudpipe's Avatar
In my field of work I've noticed that a lot of communications cables that are in any condition other than "office" use usually have the serial ports or ports like the serial due to there ability to withstand harsher conditions. Just my .02
