Msd map table ?????
This helped me
https://ls1tech.com/forums/carburete...dtigger-p.html
Page 6 shows what pill does what.
A lot of guys don't like the pills saying that it's too much timing. MAP timing added even if NOT hooked up it adds it in.
At the top of the page is a good read on timing curves and MAP curves. I think SpeedTiger has the best write-up on MAP timing, and will post that link in a minute.
Here....https://ls1tech.com/forums/carburete...dtigger-p.html
CRUISE TIMING
"Above 6.0(at higher vacuum levels) the MAP timing ramps up to 19 degrees bringing the total timing to as high as 46 degrees. These higher cruise timings were very typical on many cars I have worked on over the years. This works for low load cruising because the volumetric efficiency is so low(meaning there is very little cylinder filling at low load cruising). All of this is dependent on vehicle weight, gearing etc".
This 46 and 58 degrees of timing is whats messing with me.
I am tuned with the lap top now, but haven't hooked up the map yet. I will once I get the base timing exactly where I want it. Sense the map adds to the base timing ,I cant see building a map curve until the base is where it is going to stay. Make sense?
Just remember room pressure is typically around 15 psi. If the manifold pressure is less than that, then it is under vacuum. the lower the absolute pressure, the higher the vacuum.
So short answer is if you DON'T have a working MAP sensor then ZERO OUT THE MAP TABLE AND DON'T USE THE PILLS.
I have not used the MAP features yet, so I do not have much advise at this time. My beater truck, the 94 gmc with the 09 4.8 is about to get a MAP and the AC installed since it is to daily driver duty so the wife can use the crew cab.
Oh, and newschool72 is right. According to the instructions the 6012 box adds 20° of advance.
CRUISE TIMING
More timing is not necessarily good and less timing is not necessarily bad. Optimal timing is best.
So, that brings you to the question of why more timing is a good choice under high vacuum low load conditions and why less timing is needed under low vacuum high load conditions.
An engine is nothing more than an air pump. It is a pump of a specific size. So, the engine is always trying to pump its size in cubic inches of air every two revolutions. So, when you put a throttle body or carburetor on top, it is restricting the pump. This restriction causes vacuum. This restriction also reduces the efficiency of the pump. Therefor, the cylinder are not able to fill to capacity with air and fuel.
Since the cylinder has less air and fuel when the throttle is mostly closed, there is less air and fuel to squeeze on the compression stroke. Because there is less air and fuel to squeeze, said charge is under less pressure, when the air fuel mixture is under less pressure it will burn slower and less efficiently. In order to increase the pressure and get a complete burn of the lesser charge, you have to light the fire sooner (advance the timing). When you time this just right, the efficiency of the combustion increases, This improves fuel economy, reduces emmisions and improves throttle response.
As you open the throttle the restriction of the pump (the engine) decreases. This reduces vacuum and increases volumetric efficiency (the ability of the engine or "air pump" to fill its cylinders completely). Now that the cylinders are more full, the air fuel mixture is put under more pressure on the compression stroke. Air fuel mixture under more pressure burns faster and more efficiently so it requires less timing to get a complete burn and reach peak pressure at the ideal time to impart the most force on the piston.
So, you end up with this relationship:
The more the throttle is close, the more restriction, the more vacuum, the lower the volumetric efficiency the more timing is needed.
The more the throttle is open, the less restriction, the less vacuum, the higher the volumetric efficiency, the less timing is needed.
This is why guys with turbos and blowers reduce their timing. Because the volumetric efficiency is higher. Therefore the air fuel mixture is under more pressure. So, it burns faster and more efficiently and needs less timing to get a complete burn and impart the most force into the piston.
One warning: Too much timing under a heavy load can cause the pressure in the cylinder to rise too fast. When this happens the air fuel mixture can create so much pressure that it explodes instead of a controlled burn. This is what people refer to as: "spark knock", "pre-ignition", "rattle", "detonation" etc. This is the fastest way to destroy an engine by breaking the pistons, rings, head gaskets or in severe cases rupture a cylinder. This is why you never go too far with the timing under a heavy load.
That is as complete of an explanation as I can manage off hand. I hope that helps.
Spark before TDC to get the fire going so at TDC the full combustion happens to force the piston down. In a perfect world.
Now IF the spark was to happen a little late and full combustion happened as the piston was already starting down, you loose some force (HP/TQ).
Now IF the spark was too early causing full combustion as the piston was still on the way up... somethings got to give (piston,rod,crank)
Another way to think about it....take 2 hammers and hold one out, take the other one and hit it. It "bounces away" (the bounce is combustion lets say) so one makes the other move in the opposite way. Great.
Now too much timing... Pre-ignition/Detonation/Spark knock... take the 2 hammers and hit them together....watch how they bounce apart... not what you want to happen inside a motor.
