Finally sprayed the Mustang
Car is 6.0 LS3 heads, pat G cam, etc etc. Glide, 4.56 gears. Car weighs 3050# with me in it.
Ran a 6.83 on motor with a 1.56 60'
on a 100 shot it went 6.35 with a 1.44 60'
Was on 93 octane with 25 degrees timing with BR7EF plugs gapped .030
Fueling looks good, but straps look like they may be a little hot which is weird pulling 6 degrees. But it's a starting point
You have me dead curious how mine will run now, but I'm going to a 150.
What was the mph on motor and the gas? Where the videos at? Lol
6 deg is a bunch pulling out just for 100 shot,, also I think 30 gap is too tight for just 100 shot too,, but that's just one guys opinion...
Agreed on the dope tune, you are pulling the same timing and have the same gap as I do on a 150.
http://www.youtube.com/watch?v=8dWUO...ature=youtu.be
Also anyone running a front mount distributor ?? if so whats your timeing set at on motor..??..just curiuos......
Wish me luck, I'm 6.9 all motor, so hopefully my better than yours first gear might get me into the 5.9s that I'm looking for, but I doubt it.
On the same nitrous jetting (53n/47f) and with the same plugs/gap, mine ran best with 27 degrees of timing, which is also 6 degrees pulled from where mine runs best NA (33 degrees). I can't explain it either but it likes what it likes.
Our NA vs. N20 times are also similar, with yours being slightly quicker on both. Mine goes 7.0's on motor and and 6.40's on the 53/47 jetting, but our overall gains are comparable.
Do you have a pic of the plug straps that look too hot?
LOL
