Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Hood clearance?
Old Apr 4, 2014 | 11:12 AM
TODD SPANGLER's Avatar
Default Hood clearance?
Does anybody know if a carbed LS fits under a stock Trans Am Firebird hood? Which intake was used if they did fit and is there any modifications needed to make it fit?
Old Apr 4, 2014 | 08:24 PM
newschool72's Avatar
What year model TA you have? If its a second gen, a carb intake isn't going to work without something on top of it to add about 4-5".
Old Apr 4, 2014 | 08:34 PM
chickenbalLS's Avatar
Third gen for me 4" cowl perfomer rpm intake with a drop base aircleaner barely fits. bmr ls swap k member.also 1" spacer for methanol injection.
Old Apr 4, 2014 | 09:36 PM
ZONES89RS's Avatar
In-Zane Moderator
I have fit a carbed LS with a performer intake and no ain't cleaner under a third gen hood, otherwise it needs a cowl.
Old Apr 5, 2014 | 08:34 PM
It's a 4th generation firebird. I'm thinking of getting rid of the fuel injection.
Old Apr 6, 2014 | 03:07 PM
I don't think you will be able to pull it off without cutting your cowl and running some kind of 4+" hood scoop. Its not just about clearing the carb, its also about having enough room above the carb to get all the undisturbed air your engine needs. IMO, you need a bare minimum of 3" above the carb to let the combo run to its potential. 5" would be even better!
