MSD 6010 problem.... Won't sync?
I have a 408 24 tooth engine. Its very hard to crank. It starts intermittently. It usually will start with a jump vehicle or a full charge battery. However it has to spin way more than any engine I have ever had.
I am aware of the cranking speed problem and have ordered the MSD starter (second starter as they sell two of them) 50952 is the high speed starter 5096 is a regular speed starter and IMO isn't much better than the stock starter.
I just replaced the battery with a 1000 cranking amp MTP interstate battery.
Other guys here have had issues firing off then they say their engines loosened up or sync'ed and were easy to start after that. This isn't my case, mine is hard to start every time. After running it is questionable whether it will restart, every time. It has to spin like crazy to crank, every time.
It does not show cranking speed while cranking the engine over. After it starts it shows revs perfectly.
It's rev limiter sounds like a shotgun going off. unlike my previous engine that would just stutter. It also hits it very early compared to what its set at. AKA... rev limiter goes off before 7000 and its set at 7500
I have changed out the crank sensor and it does the same thing.
Any idea if the crank sensor needs to be a certain distance from the crank?
I know its not hitting the crank, but I wonder if being to close could be a problem? I know this distance is pretty much fixed into the block and getting it closer would require machining.
Looking for ideas from anyone that had similar issues. The box is grounded to the battery. The voltage to the MSD is within spec over 11 volts while cranking. Hooked MSD to another lone battery with 12.8 volts and it still would not start.
MSD tech thread.
Stuff for anyone else having to troubleshoot their MSD 6010.
http://www.msdignition.com/forum/showthread.php?t=20599
Stuff I have picked up elsewhere.
Brown wire on cam sensor should read 8 volts
violet wire on Driver side coil pack should read 5 volts
Orange/yellow wire on crank sensor should fluctuate 4-8 volts while cranking.
Orange wire on main harness should have 5 volts.
If any of this information seems off lmk.
A 408 is obviously an aftermarket crank, I would suspect the aftermarket crank reluctor wheel.
MSD tech thread.
Its not looking good ATM.
I have tried two known good boxes and 2 harnesses. 3 crank sensors off running engines. Same problem. I am hoping someone can give me some direction here. 1000.00 for a distributor set up is a crazy expenditure when I bought this engine as a short block built by a sponsor here. I would think they would know whether the cranks they sell need extra work to make run with a MSD. Or won't work with the MSD.
It sure does seem like the reluctor needs to get closer to the wheel or the signal just needs to be stronger (more volts). Thus the reason it cranks with the battery at 14.2 volts. And probably the misfire like the box is low on voltage.
WTH.
I remember this problem use to be common in the early years of the box. Guys with aftermarket cranks had this issues. MSD made some firmware changes to get the thing to work for quite a number of guys. But there was still the occasional guy who had no luck.
FAST makes an ignition box for LS motors. It is also possible to use a stock PCM. I would bang on MSD first.
I am trying to get MSD to help me on this. I think I just have to get the right tech. The techs I'm getting on the phone say there is nothing that can be done. They say all the new boxes have the updated firmware.
The stock starter turns the motor fine, the MSD won't tell it to spark. Great strategy to sell their $300.00+ starter. To bad their starter don't fit anything.
MSD 60952 Picture right here if your searching.
Last edited by TTur1996; Jul 24, 2014 at 09:14 AM. Reason: For some reason I hit quote and it messed up.
The 5906 tucks fine, the high speed 59052 is what's pictured and sticks out a lot. The 5906 turns like a stock starter IMO. Never tried the 59052 as it would not fit.
