Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
breather setup
Old Nov 30, 2014 | 07:21 PM
sbf's Avatar
sbf
Default breather setup
can you guys post up some pictures on how u did your breather set up.catch can,valve cover,valley cover.i hear alot of stories of strokers haveing blow by from crankcase pressure.
Old Dec 1, 2014 | 12:02 AM
LS1-450's Avatar
On a stroker, it's not only from crank case pressure. It's the combo of crank case pressure & piston rock caused by the piston skirt traveling further out of the bore on the down stroke. So, breathers can help, but generally won't completely resolve the issue.
Oil fill cap breather on one side & valve cover to catch can w/ breather on the other. If you run a PCV valve, then no breather on vacuum side cover.
Old Dec 1, 2014 | 04:47 AM
Doug G's Avatar
How I did mine....
both covers tied to a catch can and a filter in the fill cap.
