Timing Help Please!!!!!
HYD. HYD
Gross .622. .612
Duration @
.006 Tappet Lift 287. 293
Valve timing open. Close
.050. Int: 10. BTDC. 46 ABCD
EXH. 56. BBDC. 8. ATCD
108.0. INTAKE CENTER LINE
Intake. Exhaust
Duration. @.050. 237. 244
Lobe Lift. .3660. 3600
Lobe separation. 111.0.
This is a carburated set....I have a 6.0 LQ4 with 243 heads...This cam i just described with 660 dual lift springs...ported oil pump...headers...X pipe.....750 double pumper carb....Victor Jr intake....200r4 with 3600 stall.....373 posi trac......In a 86 ss monte carlo....I need help with the timing...graph please...need help with setting the timing also....need help with setting map...do i set it up according to my stall.......Please help thanks in advance.....could anyone send me a graph to go by...This is my email. ......Daldrick71@Gmail.com........thanks alot guys......
Speedtigger has/had a combo close to yours and right near 30*, My combo is similar but with LS3 heads cut .050 for approx. 10.5:1 running 93 pump **** and 32-34* flat-lined from 1000 to 8000 (7500rpm limiter).
As above, good read
Every time i tried something fancy it would act up.
