Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Front mount distributor setup (timing)
Old Jul 21, 2015 | 09:55 PM
jholland's Avatar
Default Front mount distributor setup (timing)
Iam running a front mount distributor and crank trigger on my ls3. What should I set my start up timing at, right now it's at 33 degrees. Iam looking for advice from someone running the same setup.
Old Jul 22, 2015 | 03:02 PM
speedtigger's Avatar
Old School Heavy
If you want advice on timing from someone with a similar setup you will need to give the details or your setup. Such as compression ratio, quench, camshaft specs, intake manifold, carburetor, exhaust, stall converter, vehicle weight etc.
Old Jul 25, 2015 | 10:12 PM
dogsballs's Avatar
I run a dizzy, with 6.0 with 11.9:1 comp on e85, i was locked out with 26degs
