Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
cam question...
Old Feb 22, 2016 | 07:14 AM
M7A1V's Avatar
Default cam question...
Edelbrock 2215 - Edelbrock Rollin' Thunder Hydraulic Roller Camshafts
with a 670 St.Adv. carb.
I now have the...
MSD Ignition 2910 - MSD Atomic EFI Throttle Body Systems
question, is there a better cam?
05 stock 5.3
Old Feb 22, 2016 | 08:18 AM
Greg.H's Avatar
A better cam for what purpose? "Better" can be very opinionated. I have the stock 190/190 114 cam in my 5.3 and right now I consider it a better choice than most because I have a 3.08 rear and it's my DD.
Edel 2215 specs: 220/220 300/300 .510/.510 111
Old Feb 22, 2016 | 02:43 PM
M7A1V's Avatar
I put the Edel 2215 in because of the carb. now that I'm running aftermarket EFI I was wondering if I need a different cam.
thanks for your time...
Old Feb 22, 2016 | 07:42 PM
Greg.H's Avatar
Ah, I see. Generally, cams for EFI have less overlap in order to create a strong vacuum signal. So the cam that you have now may not be optimal, but I don't know if you NEED a new cam. How does it run now? And what do you use the car for? What trans and rear gears?
Old Feb 22, 2016 | 08:34 PM
M7A1V's Avatar
runs great. street use, 700r4 w 3:55 rear gear w/Detroit locker. was mainly wondering about the...overlap.
Old Feb 22, 2016 | 08:44 PM
Greg.H's Avatar
Well, if it runs great then I wouldn't bother with a new cam.
