Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Ign timing w compression and pump gas
Old Jun 20, 2016 | 08:38 PM
OkieDave's Avatar
Default Ign timing w compression and pump gas
A friend told me I should only use 20* timing. I tried it vs. The 27 I had before and it seems to like it. I'm pump gas 421 " with about 12.5 or so comp.
Old Jun 21, 2016 | 11:42 AM
OkieDave's Avatar
Also, pistons are .010 out of the hole and gaskets are .041 leaving .031 quench. Another question: is it necessary to re-torque heads after heat cycle?
