Lq9 newb, please help
Hello all, new to the site. I have an 89 OBS truck with a Lq9, stock 243 heads, holley dual plane, ultra dp carb, LT headers. I intend the truck to be a street, strip machine, and will be using a 400 trans. My inquiry is what cam should I go with, stall, spark plugs, timing curve. Any and all help is appreciated. I apologize in advance if I have posted incorrectly or in the wrong section
You are using a heavier vehicle and will need to keep the cam on the conservative side to promote lower end torque. A TR6 plug is the general pump gas NA plug I use.
Get with Speedtigger through PM and he can help spec a cam for your use with some information he will need form you. From there, call circle D or someone local if you have the option, let them help you decide what will work best for the truck. A 4.10 gear set will help get a fat girl rolling as well.
