Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Jetting changes after changing heads
Old Feb 22, 2018 | 07:02 AM
steves86ta's Avatar
Default Jetting changes after changing heads
This probably sounds like a stupid question but I did search and can't find what I'm looking for
I have a 5.3 that I built that was dynoed at Westech
It is dialed in and runs perfectly
However it's time for me to buy some better heads and I don't want to spend the money to do a dyno again
I am horrible at jetting. I can never tell what it is the engine wants
My question is what direction will the tuning need to go?
I am going from stock 243's to probably the tsp/PRC stage 2.5 5.3 heads.
They should flow quite a bit more.
My common sense tells me I will need bigger jets. But in the slight research I did, I found the opposite, people saying they had to go smaller on jets with better flowing heads?
Thanks
Old Feb 22, 2018 | 04:25 PM
Doug G's Avatar
Buy and install an AFR meter
SO much easier than reading plugs
https://www.summitracing.com/search/...oview=SKU&ar=1
OR
Old Feb 22, 2018 | 04:41 PM
Pop N Wood's Avatar
+1
You're dropping a good bit of money on heads and I would hope matching cam. Think of a wideband as an investment/tool tax. You can even tune your lawn mower with it.
As for jets I would think it will be almost impossible to predict. Just have to try it and find out.
Old Feb 22, 2018 | 04:51 PM
steves86ta's Avatar
I have one but I just bought new headers and don't want to weld a bung into them. It's on a jet boat
Old Feb 23, 2018 | 05:17 AM
Pop N Wood's Avatar
Buy this
Amazon Amazon
I don't have one and from what I have read the reading can get corrupted by outside air. One of the comments said to add a foot or two of silicon hose to get a sample farther upstream
You know if you increase the air flow enough you may need to switch to a larger carb.
Old Feb 23, 2018 | 06:14 AM
steves86ta's Avatar
Originally Posted by Pop N Wood
Buy this https://www.amazon.com/Innovate-Moto.../dp/B000CO9MF8
that's a good idea
