Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
wiring custom
Old May 17, 2018 | 05:32 PM
dloco's Avatar
Default wiring custom
I have a ignition switch wired up to the starter through the neutral safety switch,that goes to the the starter relay along with a seperate relay hooked up to a oil pressure safety switch that is wired up with a electric fuel pump through a distribution block and fuse block going to a 100 amp circuit breaker then to battery. installation says to hook up oil pressure safety switch spliced into the neutral safety switch to the starter after it goes through a distribution block first/ is that correct?
