Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Voltage help
Old Oct 14, 2019 | 08:49 PM
chines72's Avatar
Default Voltage help
I did a carbureted Ls swap with fans, electric fuel pump, msd 6014. I bought the March performance serpentine kit with the GM cs130 140 amp. At idle my gauge reads like 12.5 and driving it goes up to like 14.At night my lights are fairly dim at idle but get brighter when driving. Is that normal or is something going on????
Old Oct 15, 2019 | 08:46 AM
B52bombardier1's Avatar
Use a multimeter and check the running voltage at the battery at idle. I'm predicting it'll be higher than the gauge at the battery with the multimeter. As for the dim lighting, could be wire too thin or poor grounds. That alternator should have plenty of amps.
Rick
Old Oct 15, 2019 | 06:10 PM
Doug G's Avatar
Can you change the pulley size to spin it faster ?
Sounds like it's not being excited.
http://www.pirate4x4.com/tech/billav...art2/#csseries <--good reading
