Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Holley split intake.
Old Nov 18, 2019 | 10:16 AM
youngengines's Avatar
Default Holley split intake.
Anyone tried the new Holley split intake for LS3 heads? Part number 300-291 .
Old Nov 18, 2019 | 11:07 AM
JoeNova's Avatar
Restricted User
I've been wanting to run the cathedral EFI version but cant find any info on them. There haven't been any dyno comparisons done.
Old Nov 18, 2019 | 11:08 AM
JoeNova's Avatar
Restricted User
Mast has a split LS3 intake that has been tested in an EFI setup and did OK, but only if you plan on running some RPM.
Old Nov 23, 2019 | 09:11 AM
I am tempted by it, but I am also afraid it may hurt..cars running real good..hard decisions LOL
Old Jan 24, 2020 | 01:11 PM
Smokey B's Avatar
From BTR...
Ok guys, sorry for the delay in testing this thing, but I finally got around to doing some more single plane testing yesterday.
The results were as follows...
100% stock GM crate 6.2 LS3
235-25x custom cam
1-7/8 dyno header
All pulls were run with EDDY elbow w 102 mm TBI
Eddy SuperVic 594hp @ 6800 490lb-ft @ 5900
Holley Split race 603 @ 6800 494 lb-ft @ 5900
TFS single ( this was ran with a very nice custom 1000cfm carb as there are no injector holes) 580 @ 6500 rpm
These test numbers are the average of 3 pulls all made to 7200 rpm .
All pretty close IMO and probably wouldn't see any difference on the track between the top 2 manifolds.
A 1 inch open spacer HURT power to the tune of 8-10 hp on the EFI setups !
Was worth a few on the carb setup .
They both had pretty much the same distribution as well.( 8 wide band O'2s and EGT'S.
Old Mar 2, 2020 | 08:47 PM
totalchaos's Avatar
I'll be trying the cath. version on my lq4.
Old Mar 22, 2020 | 06:39 PM
Cwarta's Avatar
Any updates on this? Just ordered one for my 13.5:1 compression ls1
build, Ed Curtis recommended it so we are giving her a go!
