Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Fuel pumps differences
Old Mar 5, 2022 | 12:06 PM
D.white's Avatar
Default Fuel pumps differences
My car seems slower with the (mallory 110) internally regulated fuel pump at 6.5 lbs
VS
My (holley black) with separate regulator at 6.5 lbs
at high speeds.....
Have any of you experience this?
does the the pressure drop at high speeds
street/strip set up
Old Mar 5, 2022 | 12:53 PM
You might want to check the Mallory pressure with a mechanical gauge at high speeds
Old Mar 5, 2022 | 06:13 PM
Doug G's Avatar
Holley Flow Rate:
140 gph/530 lph
Mallory
Free Flow Rate 110 GPH / 416 LPH
otherwise, 100% the same lines and ETC ?
Old Mar 5, 2022 | 07:12 PM
Woodylyf767's Avatar
Data needed. It very well could have been slower with the new one. But it may have been weather conditions or any number of things not directly related to that
Old Mar 11, 2022 | 02:10 PM
ZONES89RS's Avatar
In-Zane Moderator
Run it at the track. Only way to verify. If an *** dyno can tell then one clearly has an issue
Old Mar 20, 2022 | 01:59 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Doug G
Holley Flow Rate:
140 gph/530 lph
Mallory
Guessing your actual data explains this one. Less gas=less go.
Old Mar 20, 2022 | 06:13 AM
Doug G's Avatar
Hard to say at this point with no reply from OP.
I just remember having a fuel issue to the point where my motor would just lay over half way through high gear to the point it was like a speed limiter in new cars.
