Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Crank trigger help
Old Nov 18, 2022 | 03:24 AM
Big_John.exe's Avatar
Default Crank trigger help
I have an LS 6.0 block stroker. It has the front distributor setup and a carb. Holley hasn't been much help. But I need the msd part number for the crank trigger setup. The part number that a few has given me doesn't appear to work.. The connector is a 3 wire connection but my 6al box has the normal 2 wire connection.. Anyone direct me to the proper part number? 🙏
Old Nov 29, 2022 | 06:27 PM
ATwelveSec02Z28's Avatar
I forget how much clearance the front distributor cover has.... but you order the part no 8619, then use sensor part no 8505. then sell the Hall effect sensor in the kit.
