Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Power Numbers/Build Suggestion
Old Oct 9, 2025 | 04:49 PM
Classic_6.2's Avatar
Default Power Numbers/Build Suggestion
Hello, my build is a LS3 block with a 106+4 LSA 250/264 .610/.610 cam with a Holley dual plane intake along with a 750 DP carb. Unported 70cc rectangular port heads. Stick shift car that weighs 2,900 lbs and has a 3.73 rear gear with a 27” tall rear tire. The static compression ratio is 11.34:1 and the dynamic compression ratio is 10.11:1.
376 CI. 4.065 bore 3.622 stroke. -2cc dome pistons 1.326 compression height. 9.240 deck height. -0.01 piston below deck. 4.1 bore head gasket with 0.040 compressed thickness. .041 quench. 6.098 rod length. Intake valve closes at 47
How much power do you think this naturally aspirated setup will make? Thanks in advance.
