Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
305 help
Old Aug 26, 2010 | 07:17 PM
protestthehero's Avatar
Default 305 help
Hey, i have a 91 z28 camaro with a problem, it wont run.
So i bought it with 65k miles, nearly perfect condition and drove it. it started a little bit rough but ran smooth. i got it home and somethings happened. it wouldnt start without starting fluid and progressively got worse.
i replaced the
fuel pump
starter
spark plugs
fuel pressure regulator.
wont even run now.
can anybody shoot me some ideas to what is wrong?
Old Aug 30, 2010 | 08:29 AM
blk/slvr02ss's Avatar
Fuel filter clogged ?
Old Aug 30, 2010 | 04:52 PM
i failed to mention that i replaced that too. i checked the flow going into the motor and it was good as well
Old Aug 31, 2010 | 02:50 PM
Is it getting spark ?Could be the modual in the distributor or the coil.
Old Sep 12, 2010 | 07:41 PM
Dustytrix's Avatar
Thumbs up
It could be the injectors clogged up. But first see if the injectors are firing by using a noid light.
Old Sep 12, 2010 | 07:44 PM
formula vincent's Avatar
look at fuel pump relay ...could be bad.
Old Sep 14, 2010 | 12:44 AM
superstu23's Avatar
could be vats key problem happened to me in my 91 trans am keys get wore out and dont make good contact
