Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Please help!!
Old Aug 20, 2011 | 02:14 PM
Camarrow SS's Avatar
Unhappy Please help!!
I recently rebuilt my ls1 with forged parts and lowered the compression to 8:5 but otherwise stock Ls1 with STS turbo. It starts like crap and hangs out around 400-500rpm for about ten seconds and then idles up but in a few it will stumble and then come out of it. Also its leaning out on the higher rpm's even when we tell it to be 11.5 it won't hold it, it ends up in the high 13's before I let off. Fuel press is good when driving, replaced tps and Map sensors no fix. Seems that if I unplug the tps while running and then plug it back in, it starts way better but idles high. I'm looking at the CTS now and possibly the throttle body itself( mainly because the port on top of the TB that connects to the valve cover has no vacuum) Any suggestions. PLEEEEASE HELP !!!!!!!!!!!!!
