Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
AC Problems
Old Aug 1, 2013 | 01:05 PM
kaci_bb's Avatar
Default AC Problems
So, my fan had been blowing just fine in my camaro. Heater works, but AC doesn't. My AC compressor is fine and the clutch is engaging (only if I hotwire it), and I just had the lines replaced, along with every o-ring and what not. It was obviously a leak because the refrigerant wouldn't stay in for more than 24 hours. So now that that's fixed, after about 48 hours, 12oz of refrigerant is gone. What else could be the problem? Any ideas? This car is black exterior and interior, and has t-tops with no covers, so as you can imagine, it gets uncomfortably hot. I'm desperate.
Old Aug 1, 2013 | 01:57 PM
dtws6's Avatar
Are you sure the compressor is fine? It could be leaking out of the front seal.
Old Aug 1, 2013 | 06:13 PM
kaci_bb's Avatar
Ran some dye through it, and no signs of a leak after new o-rings were put on. That would show with a dye test, right?
