Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Plz help!!!!
Old Sep 14, 2014 | 09:42 PM
Fingas239's Avatar
Default Plz help!!!!
I have a 2000 5.7ls1 camaro and for some reason when the car is cold I will be driveing and the rpms will drop and it will start missing real bad and eventually stall out. Even if I pump the gas nothing will happen, sounds like it's sucking for air maybe but if I turn the key off and on real fast it runs fine for a min or so and then will happen agein and agein untill warm then runs fine idk what to do plz help((
Old Sep 17, 2014 | 11:11 PM
Docrocket1967's Avatar
Well since no one else has ill give it a shot, any service engine light on? Have you thought about checking your fuel filter? Could be clogged. Bad 02's maybe
Id see if any codes came up and go from there, post what they are and thatll help dial down the fix.
