Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Eletrical Gremlins ????
Old Mar 5, 2017 | 01:15 AM
shoeboxvette's Avatar
Default Eletrical Gremlins ????
2001 SS Camaro, Had something odd happen today, went for a short drive, Started the car and it died, turned key off and when it tried to start it clicked and dash and everything went dead, Key off turned on wouldn't idle and if I let off gas it would die. Help. Ideas???
Old Mar 5, 2017 | 11:06 AM
Jaks427's Avatar
Check battery/alternator, sounds to be a voltage issue. I would say check the fuel pressure at the rail but if you tried to start it and it clicked and dash and everything went dead, really sounds to be voltage issue. I would start there.
Old Mar 6, 2017 | 08:21 AM
topless2002SS's Avatar
I would take a good look at the battery cables, I have seen these corrode in odd places from the middle out, look for budges in the jacket, if you see some distortion remove and ohm out the cable itself flexing the cable around while watching the meter, if reading changes replace the cable. The won't idle is a sign the ecm lost power and needs to do a idle relearn.
Old Mar 6, 2017 | 11:57 AM
Thanks I'll give the electrical a look over,
