Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Map sensor
Old Dec 13, 2017 | 09:32 PM
Promod91's Avatar
Default Map sensor
I just put together my procharger build was told I need a 2 bar map sensor. Does anyone have a part number for this? It's for a 2002 camaro. Is there one that will just plug into my factory harness?
Old Dec 14, 2017 | 09:30 AM
Crf450r420's Avatar
I'm sure someone knows more and has a direct replacement they can share. If not I do know the LS9 3bar sensor can work. But it uses a different plug, ATS 2.0 if I remember right and the pins are swapped around. Holley systems ship with an adapter harness that I'm sure you can buy. The hole it goes into is also larger, so you would have to drill out the intake or run a hose to it so use it only if someone doesn't have a better option for you.
