Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Need help!!!
Old Jun 25, 2018 | 03:16 AM
Mycah Carter's Avatar
Default Need help!!!
Replaced front turn signal sockets now front turn signals won't blink they just stay lit rear ones work just fine but hazards light don't work at all what could the problem be?
Old Jun 29, 2018 | 09:58 PM
Crf450r420's Avatar
Did you replace the bulb with an LED light? The lack of load will stop it from flashing. You can add a load or replace the flasher with one that will work if that's the case. If still a normal bulb then you must have the wiring wrong in some way.
Old Jun 29, 2018 | 10:01 PM
Turns out it was the sockets I guess they were just faulty I bought a pair from a different brand and they worked just fine
Old Jun 29, 2018 | 10:09 PM
Crf450r420's Avatar
I ordered some off FleaBay and haven't got around to trying them. I'll keep this in mind.
Old Jun 29, 2018 | 10:15 PM
LOL I ordered mine from Amazon but checked around and the same company sells them on ebay for a little more I guess that's what I get for being cheap lol ended up going to o'reillys wired in the new pair and they worked right of the bat I believe the company was partsquared or something like that
