Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Would This Work?
Old Aug 14, 2005 | 12:06 AM
kleinIII's Avatar
Default Would This Work?
Some guy I know back in the day ordered a Camaro from the factory with a Corvette transmission and rear end. So would a vette and camaro's transmission and rear end bolt up if they were from like the same year?
Old Aug 14, 2005 | 02:58 AM
slow's Avatar
not on a ls1 vehicle
Old Aug 21, 2005 | 12:30 AM
kleinIII's Avatar
but it would work on a older model?
Old Aug 21, 2005 | 12:47 AM
ss1129's Avatar
when is back in the day? Sounds like bs to me.
kleinIII's Avatar
i'm not sure when i think he said like the 70's...
Old Aug 21, 2005 | 02:04 AM
badjuju342's Avatar
Deranged Rat Fink
You're getting BS'd ,dude. The Camaro has always been a solid rear axle and the Corvette has been an independent rear axle from the late 60's . There is NO way any Camaro ever came equipped with a Vette rear. Inversely ,it could be done but only with a LOT of fabrication. The transmission would work as they were both 350 TurboHydraMatics or Muncie 4 speeds.
Old Aug 22, 2005 | 01:26 AM
Darth Z's Avatar
Actually the Corvette first got the independant rear suspension in `63. While the IRS could probably be adapted, it wouldn' t have been by GM, because as Badjuju said, it would take a LOT of work. GM isn' t known for going the extra mile like that. The trannies should work, atleast until the LS1 vehicles. The C5 has a transaxle, that is connected to the engine via a torque tube, where as the tranny is connect directly to the engine on the F-body.
