Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Help!!
Old Mar 19, 2007 | 06:55 PM
99corvette's Avatar
Default Help!!
Ok car wont start, got in it, and it wouldnt do anything, i mean it wont make a sound when I try to turn it over. Tryed to jump it off, but the battery was fine, lights and cd player come on etc. Checked all the fuses, and they where all fine. I noticed that my security light was on, so i left the key turned over for about 2 mins, and the light went off, but it still wouldnt do anything, and ever time you try to start it, the light just some back on. So i think it might just be the chip in the key that went bad, but how would i know if it is the iginition switch or not? What else could it be?
Old Mar 19, 2007 | 07:43 PM
z28fernando's Avatar
check your starter
Old Mar 19, 2007 | 07:44 PM
99corvette's Avatar
Originally Posted by z28fernando
check your starter
Wouldnt the starter make some kind of noise?
Old Mar 20, 2007 | 06:18 PM
99corvette's Avatar
Anyone else got any ideals?
Old Mar 20, 2007 | 07:28 PM
Kalgorn's Avatar
The starter would not make any noise. The starter in my '92 Z34 went but I sort of knew it was coming because it was real hard to start for about a week. It would crank slowly for about 5 seconds before firing up. Once dead, there was no noise while trying to start up. All lights worked fine though.
Old Mar 20, 2007 | 07:41 PM
99corvette's Avatar
Yeah thats what i thought too, but my starter hasnt been acting up, it starts up fine, thats wierd if it would just go out all of a sudden, whats the best way to check it?
Old Mar 20, 2007 | 08:02 PM
Shooter_Jay's Avatar
starter relay. under your hood, swap your starter relay for your ignition relay and see what happens. I had the same problem, and that was it. Another guy on here had the same problem, I told him to try it, and it was it. I didn't even change mine, just wiggled it a bit, been fine a long time now. I made this same thread and a guy told me to try that and it fixed me for free
Old Mar 20, 2007 | 09:37 PM
99corvette's Avatar
Sweet! Ill try that when i get home and see if it helps me, where is the starter relay located at?
Old Mar 20, 2007 | 09:52 PM
It's a big fuse box under the hood. You pop the lid off. Underside of the lid should show which relay is which. They plug in like big fuses. The two big ones in there are ign and starter if I remember correctly. I think it was on the drivers side but don't hold me to that.
Old Mar 20, 2007 | 09:53 PM
you might need some pliers, their pretty stubborn, though even just a wiggle might send you on your way. Try not to break it with the pliers, I imagine that would not make your situation more fun.
Old Mar 20, 2007 | 10:01 PM
99corvette's Avatar
So just which the starter and ign relay, and if that works, i just need to go buy another ign relay?
Old Mar 20, 2007 | 11:20 PM
2000SLPZ28's Avatar
if that doesnt work, you can always take a baseball bat to it... might not get it to start but hey, it was worth a try
Old Mar 20, 2007 | 11:21 PM
99corvette's Avatar
Thats what i feel like doing right now
Old Mar 21, 2007 | 04:01 AM
MJK's Avatar
MJK
I went through this about a year ago...
After checking out the relays, check into the VATS system.Do a search,there will be tons of info.
Here is my post from back then.My problem turned out to be the VATS system.In specific,the little wires coming off the ignition key cylinder.
VATS Thread
You can get the proper resistors or use a spare key as I did to bypass it.Check your key out with a multimeter first to find out what resistance pellet your key has.Then try inserting the key in the ignition and testing the resistance coming off the plug under the knee panel coming from the steering column.The thread explains it a bit better and it sounds more comlicated then it actually is.The link on the 2nd page of the thread shows pics of how you test the resistance of your key pellet and has another link showing the bypass diagram.
Mine has been working fine (bypassed) for over a year now with no issues.Only reason I mention all of this is becuase you stated that your security light comes on.So would mine when I would try to start it.
Good luck man and hope it helps.
Old Mar 21, 2007 | 04:07 AM
MJK's Avatar
MJK
oops double post
Old Mar 21, 2007 | 04:47 AM
I have a vats bypass kit I'll sell you if you need it, I bought it but didn't need it.
Old Mar 21, 2007 | 12:38 PM
99corvette's Avatar
Why do you need i kit, i thought you just bought resistors? I will check the relays first.
Old Mar 21, 2007 | 07:11 PM
1. My car didn't start, security light on etc...
2. did a bunch of reading, peeps said bypass my vats so I bought a kit.
3. Before I installed the vats kit I tried wiggling the starter relay and that fixed it.
So I never used the vats bypass kit I bought, and I never bought resistors. So if yours isn't just the starter relay then I can sell you my vats bypass kit I didn't use, if you want it.
Old Mar 21, 2007 | 07:18 PM
99corvette's Avatar
Well i took my relay out today and cleaned the end, and put it back in, but it didnt help, i didnt try placing it with anything though. What does the kit come with?
Old Mar 21, 2007 | 07:33 PM
Well first, I would try replacing the starter relay with the ignition relay just to try another relay to see if it turns over and that one is bad, free test. But anyway, I bought the vats bypass kit off ebay and never even opened the box. So I'm sure it comes with everything a new kit should come with.
