Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Pcv Valve
Old Jul 24, 2007 | 10:45 AM
ealucero1's Avatar
Default Pcv Valve
Just Bought A 2000 Ss Camaro And Was Wondering If It Has Pcv Valve. If So Where Is It Located. It Seems That Whenever The Car Is Driven For Awhile, I Get A Small Oil Leak. Just Had The Rear Main And Pan Gasket Replaced And Still Have Some Small Oil Leaks Finding There Way Down To The Motor Mounts And Cross Member.
Old Jul 24, 2007 | 01:08 PM
Medic/Z28's Avatar
Its right next to the throttle cable. On the manifold. It should have a small 1in size rubber hose. In between that hose and the other langer hose is the PCV valve. Pull it of gently and replace it every 3000 miles. I change mine out soon than that. You can also do a catch can to prevent oil going back into the manifold. I've been meaning to do this but just haven't had a chance to.
Old Jul 24, 2007 | 06:16 PM
ealucero1's Avatar
Thanks, i found it!! The chiltons manual I have is for all f-bodys but it looks like they just added what they thought was important for the 98 and later ls1
