Needed, 99' cluster pinouts.
Old 12-13-2008, 02:39 PM
ak95ta's Avatar
Default Needed, 99' cluster pinouts.
Ive searched and checked the stickies, but i can't seem to locate the pinouts for the instument cluster in a 99 ls1 T/A. Car is a M6 with TC if that helps. Any help here is much apreciated.
Old 12-13-2008, 03:10 PM
lt4malibu's Avatar
Connector Part Information
• 1206-5803
• 34 Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A1-A2
Not used
A3
PNK
39
Fused ignition feed
A4
Not used
A5
TAN/WHT
33
Brake warning indicator lamp input
A6-A7
Not used
A8
BRN/WHT
419
Service engine soon indicator lamp input
A9
Not used
A10
ORN
640
Fused battery feed
A11
Not used
A12
LT BLU
14
(Europe and Japan) Left turn indicator input
A12
LT BLU/WHT
1414
(Domestic and Gulf States) Left turn indicator input
A13
PPL/WHT
237
(Domestic/Japan) Fasten seat belt indicator input
A14
Not used
A15
YEL/BLK
68
Low coolant indicator input
A16
Not used
A17
LT GRN
11
High beam indicator input
B1
BRN
9
Park lamp feed
B2
Not used
B3
GRY
728
Security indicator input
B4
Not used
B5
PPL/WHT
1035
Fused ignition feed
B6
GRY
1036
Class 2 serial data
B7
ORN/BLK
737
Rear compartment lid ajar indicator lamp input
B8
DK GRN/WHT
817
Vehicle speed signal
B9
GRY
8
Instrument cluster lamp feed
B10
DK BLU/WHT
1415
(Domestic and Gulf States) Right turn indicator input
B10
DK BLU
15
(Europe and Japan) Right turn indicator input
B11
BLK
650
Ground
B12-B22
Not used
B14
TAN
31
Oil pressure gauge input
B15
BLK/WHT
451
Ground
B16-B17
Not used
Old 12-13-2008, 03:18 PM
ak95ta's Avatar
Man, you are a lifesaver, thank you very much!!!!
Old 12-13-2008, 03:29 PM
lt4malibu's Avatar
no problem.
Old 12-14-2008, 05:31 AM
Old Kid's Avatar
ak95ta, what are you trying to do? The reason I ask is I'm using a 99SS wiring harness in my LS powered Rambler and I want to use the 99 gauges. The problem is the Rambler dash cut out is wide but only about 3 inches high. The 99 gauge cluster obviously will not fit. Because it's all printed circuits, it can't be reconfigured. Are there aftermarket gauges that run off the factory harness? Any suggestions or info would be great!
Old 12-15-2008, 10:53 PM
ak95ta's Avatar
Im putting the complete 99 LS1 harness, engine, into my 95 T/A, and vice versa, putting the LT4 into the 99', so swapping the dashes between the 2 cars is a must. As far as the aftermarket gauges, the serial line is the obstacle, so each aftermarket gauge has to be wired independently with the sensor.
Quick Reply: Needed, 99' cluster pinouts.
