Speartech LS3/6L90 swap package available!
Old Jan 14, 2009 | 05:20 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Speartech LS3/6L90 swap package available!
We've got a complete, brand new LS3/6L80 package available for your next project!
Package includes everything from K&N filter to driveshaft yoke. This is a fully running package that includes the LS3 engine, 6L80 transmission, wiring harness, ECM, ETC accel pedal, MAF sensor, starter, accessory drive (minus A/C compressor), trans cooler lines, fuel rail covers, etc., etc.
This was all purchased brand new for our harness/controller layout and development and has only been run here in the shop. The ECM and TCM will be programmed for your project.
The new 6L80/6L90 transmission is the upcoming hot ticket for swaps. Be the first on your block with this 430 horsepower setup!
$12,000 plus shipping takes it all! No piecing together to install it, it's all here. Does not include A/C compressor or catalytic converters.
Come and pick it up and you can watch in run before loading it up!!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 14, 2009 | 07:14 PM
SPDMETL's Avatar
How do the dimensions of this trans compare to 4L65E ? Or 4L80E ?
Old Jan 14, 2009 | 07:51 PM
Bo185's Avatar
4l60/65/70 vs 6l80 (the 90 is little longer than 80)
Old Jan 15, 2009 | 11:44 AM
Speartech's Avatar
The 6L80 is slightly shorter than the 4L60E. If you follow along on our swap project into the 2001 truck:
https://ls1tech.com/forums/conversio...l80e-swap.html
you'll see we had to use a longer driveshaft with the 6L80.
As you can see in the pics above posted by Bo185 the 6L transmissions have more girth to them (they don't taper down as quickly) so there's a good chance some tunnel mods may need to be made. In our truck project we didn't need to modify the tunnel at all.
__________________
www.speartech.com
Old Jan 15, 2009 | 12:42 PM
Bo185's Avatar
John, I have also wondered about the 2wd vs 4wd trans. Is there a short output (4x4) like the 4l60/80 and a longer one for 2wd?
Is there a transfer case adapter or do the transfer case bolt right to the trans?? (what it looks like)
Also don't both 6l80/90 have 32 spline out puts as well?
Thinking of adding one to my 4x4 and was wondering on out put and which trans to get (4x4 or 4x2)
Thanks!
Old Jan 15, 2009 | 02:27 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's a hefty hunk of transmission. I bet that thing is comparatively rather heavy.
Old Jan 15, 2009 | 02:55 PM
Bo185's Avatar
From GM media site http://media.gm.com/us/powertrain/en...09/09truck.htm
6l80 weight
Transmission weight:258mm converter: Wet: 94-96kg ( 207-211lb )
Transmission weight:300mm converter: Wet: 102-104kg ( 225-229lb )
6l90 weight
Transmission weight: w/ 300mm converter
Wet: 109kg ( 240lb ) estimated
4l60 weight
wet: 74 - 88.5 kg (163.2 - 195.0 lb)
4l80 weight
wet: 115 kg (254 lb)
Their no more weight than a 4l80
Old Jan 15, 2009 | 02:58 PM
GMCtrk's Avatar
Speartech,
Do you have anything for the 99-07 trucks wanting to swap in the 6l80?
Old Jan 15, 2009 | 04:48 PM
snketr's Avatar
Or anybody wanting to put them behind a 58 tooth reluctor wheel LSx motor?
Old Jan 15, 2009 | 07:57 PM
skyhighsami's Avatar
no title here
I think that is the problem about swapping that tranny is with out the 58 tooth reluctor wheel the ECU can't control it and no one makes a stand alone controller for it
Old Jan 16, 2009 | 10:49 AM
Speartech's Avatar
Thanks!
I don't know enough about the 4WD stuff to give you many details.
On the 2WD units, the 6L80 output shaft is the same as a 4L80E, but on the 6L90 the output shaft (and driveshaft yoke) is quite a bit larger.
__________________
www.speartech.com
Old Jan 19, 2009 | 05:27 AM
rsz288's Avatar
Almost an understatement John
Here's a shot of the 6L90E yoke alongside a TH400 yoke, which is not an exact fit on a 6L80, but apparently will slide on:
With some background here:
https://ls1tech.com/forums/conversio...does-go-2.html
Cheers!
Old Jan 23, 2009 | 11:24 AM
Speartech's Avatar
Originally Posted by GMCtrk
Speartech,
It will work as long as you change the engine to a 58X reluctor. The problem on the newer vehicles is what other modules will be affected by the ECU change. I have no way of knowing what the IP will say, what the driver info center will display, or any of that stuff.
You can look at our 2001 truck swap and see what we had to change to get the gauges working properly, etc. I still don't have back-up lights or starter interrupt. A person could probably custom make a bracket to mount the switch on the side of the trans for those functions, but my main customer base is aimed at the older cars and trucks, not the newer ones.
I wish I had answers for all of the issues on swapping into newer vehicles. You can't imagine how many calls I get to upgrade 05-06 GTO's and Trailblazer SS vehicles to the 6L80/6L90 transmission!
__________________
www.speartech.com
Old Jan 23, 2009 | 12:50 PM
Speartech's Avatar
Cheers!
Here's a view looking into the yoke splines of each (6L90 on the left):
The 6L90 is definitely a meaty piece!
__________________
www.speartech.com
Old Apr 23, 2009 | 12:07 AM
08sierra's Avatar
Can the 6l80 be swapped into 2008 4x4 sierra that orignally came with a 4l60e
what would be needed to make it work. i know i would need a new column shifter with the tap shift buttons, probably a new gauge cluster that has the manual mode (m1, etc.). what about the wiring and the ecm? If this is possible where could i get all of this? dealer?
Old Apr 23, 2009 | 02:38 AM
rsz288's Avatar
Just a matter of $$ &/or Time really. Understand it has been done with 2WD's, and possibly a 4WD. A guy in Europe, one in Vegas, and another guy. Search here: forum.efilive.com .
The challenge with a later model is that most control modules (ECM/TCM/BCM/ABS/etc) need to be matched, so if there is a similar truck with what you want to do that GM makes......
Old Apr 23, 2009 | 11:11 AM
Speartech's Avatar
It's a very do-able swap into older vehicles. We are selling many systems for these swaps now, complete with fully functional tap shifting.
But doing it into an 08 may work, or it may open a hornets nest of problems trying to get everything working as the factory intended. There are MANY differences between a new vehicle that came with a 4L60E vs. one that came with a 6L80.
__________________
www.speartech.com
Old Apr 23, 2009 | 11:14 AM
Speartech's Avatar
BTW, the LS3 package above has been sold!
__________________
www.speartech.com
Old Apr 23, 2009 | 05:10 PM
Bo185's Avatar
I think theres a guy on PT.net with one swapped as well.
http://www.performancetrucks.net/forums/
Old Apr 24, 2009 | 05:34 PM
FastKat's Avatar
Which one of those new-generation 6 speed transmissions is the equivalent of the 4L80E? Steel planetaries, clutches only (no bands), able to take brutal beatings straight out of the box with no mods, etc?
