LS Vega
Old 10-31-2009, 11:53 PM
  #61
Rock_Daddy's Avatar
Maybe a little after market heads here.... Solid cam there... a few things.
Old 11-01-2009, 04:17 PM
  #62
68lemans's Avatar
Any interest in a LS9block ? $1,500
Old 04-03-2010, 10:34 AM
  #63
Rock_Daddy's Avatar
Probably have some good updates in a week or so.
The changes to date from last years engine is.
Mast Ls3 black label heads
~.800 lift solid roller
14.4 CR gas ported pistons
Dry sump oiling system.
And the testing is going to start using this:
Old 04-03-2010, 10:51 AM
  #64
Jimbo1367's Avatar
Default passing out
Originally Posted by cam75w/ls1
How's the car gonna drive itself after you pass out from the launch?
Lmao. good one.
Old 04-03-2010, 10:52 AM
  #65
Jimbo1367's Avatar
[/IMG]
Damn dude. killer heads and crazy lift.
Old 04-03-2010, 08:42 PM
  #66
jomomma's Avatar
When can we get some more vids?
Old 04-18-2010, 11:00 AM
  #67
Rock_Daddy's Avatar
My new Billy Briggs build for the Vega should be on the dyno as early as this Monday. Here is a sneak peek. Just finishing some rocker adjustments and she is ready to roll. Its looking pretty sweet to me.
Attached Thumbnails LS Vega-4531598278_f8f981483c_b.jpg   LS Vega-4530967329_86058935d8.jpg   LS Vega-4530965001_1dd224437e_b.jpg
Old 05-10-2010, 03:39 PM
  #68
Rock_Daddy's Avatar
Just a little update. I'm a couple week behind as everyone is used to but the engine got a little engine dyno time today. After some warm up and break in load we had to play around a little to get some fuel and timing setup for the e98 which I imagine is a little odd (I'm not a turner) When it came time to make some actual power pulls to see where we were it quickly tapped out the 65lb injectors at 6000rpm so we didn't get much in the way or tweaking. I should have some 83lb ones in tomorrow morning. 700hp at the crank is what would make me happy and anything better is all gravy. It looked like it made 640hp when we cut it off and it Rich said it was just winding up. Power started moving in good at the high 4k range with a 140hp increase from 5k to 6k when we cut it off. (if I remember correctly) We haven't played with timing or much of anything really so I'm feeling pretty good I will get to the 700 mark which should put the little Vega into the 8's.
Hopefully the good vibes continue for tomorrow when we really get to play with it. Fingers crossed!
Old 05-10-2010, 08:57 PM
  #69
jomomma's Avatar
How many cubes are you running?
Old 05-10-2010, 09:06 PM
  #70
Rock_Daddy's Avatar
Originally Posted by jomomma
how many cubes are you running?
416 ci
Old 05-11-2010, 06:28 PM
  #71
Rock_Daddy's Avatar
Ok put 83's in it today and buried those at 690hp @ 6500rpm. The thing should rev way into the 7500 area.
After changing some of the math I was using we are putting 110-120's in them next.
Old 05-17-2010, 06:31 AM
  #72
Rock_Daddy's Avatar
Well I don't really have any additional numbers as we moved from the engine dyno unfinished so we could get the car together and run it. Tuned on the chassis dyno to get a safe baseline and run it on Sunday. The chassis dyno never gives me any good numbers with my 8 inch 5500 stall so I don't worry about those numbers too much(and I keep them to myself lol). I bet we will get it back on the engine dyno soon enough.
But now for the better stuff. Took it to Milan for some test and tune and I'm chasing some bugs with the trans brake so I didn't use it. Had a few test hits and 1/8 mile attempts then went for a full 1/4. First run was a 9.28 @ 143.5 foot braking it.
Its a little soft top end but we are still learning how the e98 acts and didn't want to push it. Not bad for a first pass though. Here are a couple pics on a nice summer day!
Old 05-27-2010, 04:21 PM
  #73
Rock_Daddy's Avatar
Check it out. Got some props in the old Vega during my licensing runs at dragzine.com.
http://www.dragzine.com/news/e98-fue...n-8s-in-sight/
Old 06-08-2010, 08:09 PM
  #74
Rock_Daddy's Avatar
Some stuff from the PINKS show in VA this last weekend.
Old 06-14-2010, 11:13 AM
  #75
BlazinT/A's Avatar
this thing is so nice i want one too but have no mooolah
Old 09-18-2010, 05:37 PM
  #76
Rock_Daddy's Avatar
Super Vega Friday.
http://www.youtube.com/watch?v=JuM9FigHOQI
Old 09-18-2010, 05:50 PM
  #77
Jimbo1367's Avatar
wow
Old 09-19-2010, 07:10 AM
  #78
hotrodscrap's Avatar
Rock Daddy, the car's looking quick! It's been a while since I checked out this thread, nice work. Who made the headers your running? Thanks.
-SS
Old 09-19-2010, 08:14 PM
  #79
burgers's Avatar
What the mustang run? LOL
Old 09-19-2010, 09:25 PM
  #80
78supersport's Avatar
very nice run congratulation on making it into the eights, looked like you were doing a little skating.
Quick Reply: LS Vega
