Any other power steering pumps or pulleys work with F-body?
In attempting to install the F-body pump, my suspension cradle is slightly too narrow. I looked at my 1998 Sonoma, and the pump is similar, with a 5 1/2" pulley rather than 6 1/2".
Has anyone:
1. Used a different GM pump and pulley assembly successfully for a clearance issue?
2. Know which pulleys from other GM vehicles interchange on the F-body pump?
Not sure if it will work for you or not, but Summit has one (SUM-340203) that looks like it worked for my LS2 (out of a 2005 vette) swap into a 65 vette. I had to machine some of the material off of the back of the pulley, where it mounts on the shaft so that I could mount the pulley deeper onto the pump. Good Luck with your project!
Matt
Matt
I have a pulley from these guys on my LS1-
http://www.howeperformance.com/accessories-pulleys.htm
I didn't put it on for clearance - I wanted the pump to turn faster to drive a large power steering ram, but it is considerably smaller than stock and might solve your clearance problems
Mine is the #315 'Desert Series' and is 5.375". I have a stock one sitting around here and it measures about 6.6"
Hope this helps
Hope this helps
