fuel pump help please!!! 4.8l
Old 12-15-2009, 12:46 AM
racergrn's Avatar
Default fuel pump help please!!! 4.8l
i'm in dire need of a fuel pump... donor truck was a 2000 silverado with the regulator on the fuel rail does any one have suggestions on a fuel pump that i should use, im tore between a walbro gsl392 or airtex 8248 i do have the fuel pump from the donor truck that i could install in the RCI fuel cell would this be the better route o go?
Old 12-15-2009, 04:23 AM
dec010974's Avatar
Default fuel pump
hello. what kind of setup do you have? in my case(gmc '87 c10), i used a walbro 255 in tank fuel pump, connected it to the existing fuel sending unit, and installed a filter before and after the pump. the fuel rail i used had no regulator or return line. the filter/regulator for this application comes from a 99 corvette. look on the web or pm me and i send pics.
Quick Reply: fuel pump help please!!! 4.8l
