LT1 to LQ9 swap
Old 07-13-2010, 11:41 AM
lethal bird's Avatar
Default LT1 to LQ9 swap
Ok, Its obvious why I would want to do this my question is roughly how much would I be looking at. LQ9 bottom, heads, cam, intake, computer, K member, Trans, ext, ext.
Old 07-14-2010, 11:53 AM
flame's Avatar
Depends how long you want to take to find all the deals on parts. The prob with a truck motor is that you will need to find a car oilpan, windage tray, pickup tube, intake, fuel rails, injectors, wire harness, pcm, and all the front drive accessories. What year car and auto or manual trans?
Old 07-14-2010, 01:04 PM
95 m6
Old 07-15-2010, 12:02 PM
flame's Avatar
So then you need to get a transmission, flywheel, clutch, hydraulics. I would guess you'll be $5000 easy
Old 07-24-2011, 06:11 PM
AmirGTR's Avatar
And that just the parts, right?
Would an LS1 swap cost less? Obviously the engine is more expensive but you won't need as many part changed.
Quick Reply: LT1 to LQ9 swap
