5.3L/T56 into 70 Chevelle
#41
Great build. Let me make one suggestion. That adapter through which the hoses come through will leak. Ask me how I know :-) Water comes down the inside of the cowl, down the sides of the kick panels and down through the rockers. I suggest you take come silicone and caulk the hell out of those hoses.
Andrew
Andrew
#42
You know, I've been wondering if there's not a better solution than having all the water run down that cowl and into the fender area. Has anyone attempted to fix this? Or at least come up with some solution? I know that area is a common rust spot so any solution would probably be a good one.
#45
Continuing on...
So last posts were setting the motor in the car and cutting a huge depressing hole in the floor pan. Well, we got the motor bolted in and the huge hole all welded up. Unfortunately I don't have any pics of that but it's not really rocket science right?
Cut huge hole..... wish you hadn't cut huge hole..... make huge hole go away.
Once that was done it was pretty much wire it up time. I fashioned my wiring out of a 4-fuse block from Pep Boys and two relays from Frys. Keyed on for the entire circuit and a fuel pump relay. I ran my fuses combined much like the factory harness does. Bank one (coils,inj) on 1 fuse, bank 2 on another, 02's on one, MAF/TAC on another...
I sent my ECU to www.wait4meperformance.com and Jesse Bubb programs them for $85. I told him what I deleted, what I was running and the tune came back pretty good. I've been running it now for 4100 miles and haven't had any problems. I'll be installing a cam soon so that tune will change.
Here's where I mounted my ECU. I worked with the truck harness and didn't add any wiring to lengthen it. This was a fairly logical place to put it out of the way of water etc. I used the Humer H2 ECU mounting bracket which was about $25 from GM. I trimmed it and mounted it to 2 L-brackets I purchaed from Home Depot. Using some threaded bar stock I made made hood hinge studs by cutting a 3" piece and jam nutting it to the existing fender nuts. This allowed me to bolt the ECU bracket on the backside of the fender while using a nut to fasten the hood hinge. I can adjust the hood hinge without tampering with the ECU mount and vice versa.
So I have my ECU outside under the fender, and my fuses and TAC box are inside the cab ran through a 2" hole behind the drivers head.
The pedal I sourced from a junk yard and fortunately it was the correct one. All I did to mount it was cut off the return spring, cut the rod down quite a bit and then drill a hole on the end to mount my factory Chevelle pedal.
I reused one of the existing pedal holes in the firewall and just screwed the other through the firewall. I made sure the pedal matched the original pedal location..
#46
Wade70SS,
I just read your build thread and saw you're in the Dallas area. I'm in Plano and thought I'd show you some N. Texas support. Man, I wish I had seen your build thread earlier as I'm chest deep in a 5.3/T56 swap into my 69 Chevelle!!! I bought a 5.3 with 120k miles for $500.00, but came with no accessories at all, only the truck intake and exhaust manifolds. I've since switch to a LS1 intake, cable throttle body, C5 vette balancer and water pump with the plans to run the vette accessories. The T56 I got for 850.00 out of a 98SS Camaro with 34k miles. With some craiglist shopping, I found a used flexplate, clutch and master cylinder for cheap. Just need to get the slave and firewall bracket and that's done. My build has stopped now as I'm confused on what oil pan to use and see you had an interesting approach to setting up your motor. I have S&P type mounts with a 1 inch set back along with tall/narrow energy suspension bushings. I've probably spent countless hours researching the pros and cons of each oil pan that will work to give the proper ground and tie rod clearance. Seeing your approach I may try and copy and use one of the S&P modified pans. Have read some possible oil starvation issues, but I'm building a daily driver, not a track car so hopefully I'll be ok.
I wanted to ask what did you do in terms of fuel delivery? Did you use your existing stock tank or buy a new one set up for FI?
Sorry for the long write up, but thought I'd let you know where I'm at and trying to get to were you are as fast as possible without spending my life savings to get this project completed!!!!
#48
Thanks!!! It's all on a budget but I just love driving it. AND you're right! Everything needs an LS engine.
One of the guys at my work was talking about getting a Nova II and I mentioned a Grand National swap. He was all about it. But then I had to burst his bubble and tell him that an all aluminum LS motor would probably weigh less than the V6 and net you the same results. "Really????"
#49
So what you are saying is silicone the hell out of that thing?? GOTCHA!!!
Andrew
#51
Sprung!
The ECU sits well above the steel inner fender. I'm pretty sure I'd have to Dukes of Hazzard this thing to hit it. Lol. Unless I'm wrong.....? It's on Eibach springs. I think if I hit it we would have other things to worry about too!
#54
#55
What was the source? If I get the pedal from a silverado that comes with the engine does that work? I thought I could just get whatever the engine had originally but I saw another post that suggested you need a corvette pedal since its metal and the others are plastic...not sure that's necessary.
#56
But again: Truck TB + Truck Pedal + Truck TAC box all from the same year/type.
Which Throttle Body do you have? Do you have the TAC box?
#58
I'm running the 01-02 TRUCK throttle body, 01-07 TRUCK pedal, and the 97-04 TAC Module pictured below.
Here's a quick reference:
#59
It's ALIVE!!
You know, I don't think there is any feeling in the world that will ever compare to the first crank up of a new motor. I mean all the blood, sweat and BEERS that go into building something by hand. Manipulating the wiring, calibrating the parts, whatever the case may be. Starting it up for the first time is always the best.
Here's a couple videos of the start up. A little improvising was done on the intake tube and was running open manifolds with the O2's zip-tied to the outlets. Either way.....It's alive.
