how do i make my factory sending unit work with high pis EFI
Old 05-19-2013, 04:39 PM
sixt5's Avatar
Default how do i make my factory sending unit work with high pis EFI
factory 65 mustang sending unit:
how do i go from a factory barb fitting to efi friendly stuff?
Old 05-19-2013, 06:19 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
The best way to do it is to cut the tip off that tube and have a AN fitting welded. An alternative is to use a compression fitting, but you will still have to cut the tip off.
Andrew
Old 05-19-2013, 09:03 PM
S10xGN's Avatar
If you're bucks up: RobbMc.
Old 05-20-2013, 12:14 AM
i r teh noobz's Avatar
Barb fitting with EFI clamps should work fine.
Old 05-20-2013, 02:08 AM
ls1nova71's Avatar
This is what I would do. Just put a piece of hose on it and clamp it. Using that sender means you'll be using an inline pump, and therefore there won't be any high pressure on it since the pump will be after it. You will have to add a return to the tank somewhere though.
Old 05-20-2013, 07:06 AM
sixt5's Avatar
Ok great. They make new senders with a return but I hate spending a hundred bucks for just a pipe that's added in lol.
Going bosch 044 with corvette filter
Quick Reply: how do i make my factory sending unit work with high pis EFI
