Zr-1 Colorado
#45
Can you give any info for the wheel size to fit stock zq8. A little larger and wider than factory is great. You said you fit 12 inch wide out back with fab work but maybe you know what I need without the fab work.
#46
9.5" is about all you can go without it sticking out to far. I usually run a 275/40/17 all around. Won't rub on the front . Scratch that ! I'm thinking s10 zq8 ! The 12"s in the rear have a finger gap between tire and frame . I had to trim the inner fender liner as well as cut a little off the frame cross brace to make it flush with the frame . They stick about 1.5" out of the bed hence the 4x4 flares to take up some of the distance. I would think a 20x10 would work great with no flare
#49
Wow that thing looks awsome. My truck Is a gmc sport blue and I'm building an aluminum 5.3. Heads pistons cam the works. Can't touch your build but should still be nice. I have the 18" gmc natural aluminum or silver not hyper silver wheels but want the ZR1 in the same finish. Thanks for the info. Do you think I can just get an adapter- spacer to fit the vette offset or do I need to change a lot more.
#53
When you say the rear, you mean the rear axle housing and all right. My factory center is aluminum. With c - clip eliminator I should be good for 650 hp flywheel. I really don't want to change my rear end so I'll just have to put in a little more homework.
