will car water pump work with truck acc.?
I used the L99 pump part #19207665 and used upper hose #9006 from napa fits perfect in my GTO and the hose ends are different sizes just like the waterpump and radiator are. Also clears my intake tube nicely.
19207665 is the part number you need for it to line up with the truck crank pulley. That's the part number that I am using.
Check out this thread for more info.
https://ls1tech.com/forums/conversio...g-vvt-l92.html
Lined up the pumps and the pulleys are an inch and a half differance in height(!). Will have to order some aluminum from Speedy Metals. Thickest I have on hand is 1 inch.
What the heck kind of car did this pump come off of??? Which port should I install the SBC water temp sensor into?
