LS376/480 Fuel Problems
I recently bought an ls3 and ran into a little problem with the fuel delivery. Since im putting it in my camaro that used to have an lt1, im having an issue with the fuel lines. I wanted to run one fuel line to the bottom of the car and use the 1999-2004 corvette fuel pressure regulator and from there run the original two lines to the fuel pump. I bought a fuel pump kit from summit that will give me the fuel pressure i need. So my issue is: Will this setup work or will it be a complete failure? Help cause im almost done
The supply should be at least 3/8". Return from the C5 filter is typically 5/16"
