LS2 into 70 Lemans Air Con Questions
Old 12-14-2011, 02:19 PM
big johhny's Avatar
Default LS2 into 70 Lemans Air Con Questions
I recently picked up a complete 2005 GTO that was wrecked. I have yanked the LS2 and modified 4l65E trans to install into a 70 Lemans Sport with factory air.
I assume the stock LS2 compressor will require the frame to be notched or I will have to purchase the aftermarket relocation bracket and pick up a Sanden.
The Lemans had it's complete factory non converted R12 system intact and I have removed it. I want to try and adapt the the GTO parts as much as possible and will redo lines as needed.
What advice can you give on the swap and making the A/C system compatible in the Lemans. What other parts do I need from the GTO and anyhting you can think of I will need to do or wire.
Quick Reply: LS2 into 70 Lemans Air Con Questions
