LT1 to LS1 97 Z28
#42
Me personally I like the LT1 rears, you can fit a 15" drag wheel easier.
98-up will work on older stuff, however 97-back rear brakes will not work with a 1998-up. It has something to do with how the pressure is split in the proportioning block..I've actually tried it and found it to be true.
#43
#47
What im wandering is how did u do the fuel lines and all that im doing thee exact same thing as u i have a 97 lt1 im converting too an LS but im stuck on the fuel tank part where the plug in is by the rear end
