Options for 5.3 w/afm
1. Keep the EFI, which is what id like to do. Possible cam swap. If i kept the efi, what do i do with the afm?
2. Drop the efi, go with Thumpr cam, Edelbrock intake/carb set up. Do the afm lifters have to be swapped out for this cam swap? If so, what lifters do i use?
3. Steer clear of the ly5 totally, or is it a perfectly fine candiate?
4. If i go the cam/intake/carb route now, and i eventually go back to efi, will that cam work with the efi?
Heads gotta come off, the AFM lifters suck then you can cam it!
Going carb will be more expensive IMHO. There are better cams out there, I'd call comp and have them spec you a cam for your nova but not til you get it all figured out as far as which way you wanna go with the 5.3.
Yes the lifters suck, just go with Ls7 lifters they are the replacement for all Ls motors.
What are you looking for? What are your goals with the Nova?
No because plastic intakes prefer different cams than carb style intakes like a tighter LSA. But I guess you'd be able to if need be. Just my .2
1: W or W/O Drive By Wire, harness, $549
2: Computer w/ tune for DBW, $250
3: Computer w/tune and Lingenfelter box for Drive by cable, $450
So first im going to get the engine physically mounted in and see if the truck intake will fit under my stock 70, hood. If so, ill get the DBW setup and run it.
If not, ill look at an LS1 intake and cable TB and go the Lingenfelter box way.
Which I might do anyway, not 100% sure yet.
I may do the cam swap in the future???
If im missing something here please chime in, I would appreciate the input! Thanks!
So, if you decide to swap pans, make sure to use a non-AFM valley cover to completely inactivate the AFM.
