01 camaro brakes lock up, 65 nova
Old 02-06-2013, 07:47 PM
silverado01's Avatar
Default 01 camaro brakes lock up, 65 nova
I have installed a 2001 camaro V6 into a 65 nova wagon.
I also installed the booster and master cylinder from the camaro.
The front brakes lock up. It will release if the bleeder is cracked or the line going into the master cylinder.
The brakes also release if I loosen the 2 master cylinder bolts.
The booster rod goes in and out easily.
Trying to determine if it is the booster or master cylinder. Any ideas?
Thanks
Old 02-06-2013, 08:25 PM
LS1Tech Sponsor
BP Automotive's Avatar
Thanks
Might not be either. I have seen TONS of brake hoses collapse on the inside when the pedal releases, and keeps the fluid in the caliper. If they are used hoses You might want to check that.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 02-06-2013, 08:45 PM
new hoses and calipers. Since it is both sides I was thinking it is not the calipers.
Old 02-06-2013, 09:14 PM
ART T's Avatar
Is your push rod too long?
Old 02-06-2013, 10:54 PM
ls1nova71's Avatar
This is my guess too. If loosening the master cylinder mounting bolts releases the pressure, the rod has to be too long.
Quick Reply: 01 camaro brakes lock up, 65 nova
