Need 4L60E wiring help
I have converted pretty much my entire harness from a 2001 silverado to use in my 32 Ford Truck Swap. The only section that was chopped was the 2 connectors that go to the PRNDL switch. I have the 2 connectors but need to know which wire goes where.
If someone could please give me a detailed description of where these wires go to a 0411 PCM that would be awesome.
Thanks
Thanks
LS1Tech Sponsor
Cavities PCM
a BLK/WHT Blue 32
b Gray Red 62
c White Blue 34
d Yellow Blue 72
a Not used
b Light Green (this wont be used, its for the interlock)
c Pink - Ignition power feed for back up switch
d Black/White - Ground
e Purple/White - Starter relay supply
f Light Green - Back up light supply
g Yellow - Cranking signal from ignition switch
If the colors on the 7 way connector are a little different it doesnt matter, the cavities serve the same purpose.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
Cavities PCM
a BLK/WHT Blue 32
b Gray Red 62
c White Blue 34
d Yellow Blue 72
a Not used
