2012 5.3 out of Tahoe engine code 0 lmg fit 08 silverado 5.3 lh6 if I
08 5.3 lh6 truck motor went,sounded like it was about to come out of truck.
Found a 2012 with 1 mile it's the lmg 5.3 0 vin.
From what I've read they both have 58 x reluctor so mine should plug in.
It's flex fuel but my 08 is not the ,the flex fuel runs either fuel but will my PCM run the injectors and parts off the 2012 .
I was thinking that I could use my intake with injectors and everything that's came off my 08 and put it on the 2012 motor and everything plug in .will my PCM by doing it this way work and make the 2012 motor run.I would like to use the injectors from the 2012 for they have no miles but didn't know if my PCM will work with these injectors or plug in ,but I will use old ones if I have to .also would like to use coil packs .
Will this work and is there anything else I need to do .I was thinking of having it tuned when done and delete the afm .
Any help or suggestions thanks
