So why did it just shut off? Here is the culptit!!!
They have different lengths to suit what you are building and it is quite affordable.
Honestly, I've had decent luck with the Gates submersible in-tank hose when installed properly if the moons line up and after I sacrifice the proper animal using the proper ritual. However for the price and the fact that OEM's (at least GM) uses this and I've never seen one fail, it's hard to beat. The flexibility of this material is a huge plus - the only downfall I have experienced is it is NOT reusable.
Here is a link for the whole list, not just the one I use which is above.
http://www.racetronix.biz/items.asp?...TpStatus=1&Tp=
Same thing happened to my GF's LQ4 Camaro, with dual in tank pumps. It would barely start and run. Pulled the sender, one hose was ruptured and both were rock hard and brittle. The other hose literally snapped when I removed it. Got a screaming deal on the car because the guy who built it couldn't figure out this $5 problem.
my dad was having fuel issues with his 75 T/A he replaced the fuel lines with an aluminum fuel line and now it runs a lot better. there is still a problem but thats because of the carb adapter plat thing is it runs better with out one but then we cant hook up the kick down cable so who knows.
Once that type of hose seats.. it is not easy to removed. it becomes very hard and is easy to crack. And if you could take it off nicely.. it most likely would not reseat once you re-install it. .that has been my experience.
My recommendation.. This is something you don't want to fail while on the Road.(just ask OldGoat !) and/or also have to fix more than once..!
Just replace everything that you can that you can or should be.. so.. Hoses, clamps, seals, O-rings.. etc.. A few extra bucks now is not going to hurt you..
BC
BC
The right stuff from the parts store is sold in one foot sections and is very expensive. I want to say around $20 or so a foot for the Gates brand. That stuff actually works (what I'm using right now for one car) and has been fine for a couple of years. The problem is price and everything has to be exactly where you want it before you make the hose. Another car of mine has the nylon straw type which allowed me flexibility once in the tank. I've learned my lesson and I'm not going back.
Funny guy Rocky. Hahaha. Some cars are too low for a sump and an external pump. Then there is the noise factor of some external pumps... I'm not against them, they have their place. One benefit is a simpler install for a lot of situations.
You can't even buy a cheeseburger at McDonalds for the price of the flex hose. Buy several and throw them on a shelf for your next swap. Quibbling over a $20 piece of hose and a couple efi clamps, gimme a break. Just do it once and do it right.
Great info and source, thx.
