92 Mustang swap
92 Mustang swap
Currently have 92 Mustang with the following parts, ls1 engine, 4L60 Auto trans
AJE k memeber, transmission crossmemeber,engine mounds, A arm with coil over kit.
Was wondering what you all would recommend for the rear? and spline? as well as Harness?
Was planing on keeping it NA no boost or turbo
Just use an 8.8 out of a GT fox and build it out.
31 spline axles are the way to go if you'll be N/A, get some killer gears for that thing!!!
They sell stand alone harness' for that swap or you have whatever harness on the motor modded to be stand alone which from my understand isn't the hardest thing in the world.
AJE also has rear tubular control arms that would be good to get ahold of.
TeamZ also sells a custom built rear end you can order from them.
I'm going to be in the process of the same build before to long in a notch, good luck!
http://www.americanmuscle.com/31spli...8693-4lug.html
Would that work? or am i better off picking up the 8.8 rear end off a junkyard?
That would be a good kit to pick up!
You can probably piece it together for a little cheaper might look into that.
As for the driveshaft I would imagine http://www.driveshaftshop.com/ would be a good place to start.
Also N/a is great and all, but boost is the best!
Get a 5.3 and throw a turbo on that thing and you'll make considerably more power than n/a on an LS1 for about the same cost! (personal opinion)
Or just spray the **** out of a 5.3 and you'll make a lot more power!
