87 Regal Swap...Can I keep the Air Conditioning?
Old 09-30-2013, 09:24 PM
Docked Wage's Avatar
Default 87 Regal Swap...Can I keep the Air Conditioning?
I've read that the coils interfere with the factory AC box. I definitely want to keep the AC down here in Florida.
Is possible to drop in an LS and still keep factory air? What's involved?
Thanks, Ken
Old 10-01-2013, 06:54 AM
bigmandengo's Avatar
Thanks, Ken
If you use the setback mounts, a slight notch to the ac box is needed.
Old 10-01-2013, 08:08 AM
i r teh noobz's Avatar
Wost case, you can relocate the coil packs.
I've also read that the AC compressor hits the frame on G-body cars.
Old 10-01-2013, 08:45 AM
N20zuki's Avatar
1in set back plates... Stock Monte Carlo SS frame mounts and clamshell block mounts and I have no notch in my heater box, and no contact with it.
Old 10-01-2013, 05:13 PM
locrzn's Avatar
Mine are fine, no problems at all on my 82 malibu wagon and we used the 09 ac compressor. You'll have to put a little notch in the crossmember which is no big deal.
Quick Reply: 87 Regal Swap...Can I keep the Air Conditioning?
